查看: 2927|回复: 1
ASM32本地汇编库
衰06-01 15:26
类人猿 发表于 2017-8-23 12:31:39 | 显示全部楼层 |阅读模式
   这个是按键精灵2014或者按键9有效。按键X版本无效。(按键2014风琪仙)
  1. Declare Function Asm Lib  "ToAsm" Alias  "Asm"(ByVal code As String,ByVal 长度 As Long) As Long
  2. Declare Function SetRec Lib  "user32" Alias  "SetRect"(ByVal 矩形 As Any,ByVal 左边 As Long,ByVal 顶边 As Long,ByVal 右边 As Long,ByVal 底边 As Long) As Long
  3. Declare Function LocalAlloc  Lib "kernel32" Alias "LocalAlloc" (ByVal wOemChar As Long,ByVal wOmChar As Long) As Long
  4. Declare Function LocalFree Lib "kernel32" Alias "LocalFree" (ByVal hMem As Long) As Long
  5. Declare Function LocalSize Lib "kernel32" (ByVal hMem As Long) As Long
  6. Declare Sub RtlMoveMemory Lib "kernel32" Alias "RtlMoveMemory" (ByVal h As Any, ByRef f As Any, ByVal Length As Long)
  7. Declare Function CallWindowProcA Lib  "user32.dll" Alias  "CallWindowProcA"(ByVal 前1窗口函数地址 As Long,byref 窗口句柄 As Long,ByVal 消息值 As Long,ByVal 附加参数1 As Long,ByVal 附加参数2 As Long) As Long
  8. Declare Function RtlFillMemory Lib  "kernel32.dll" Alias  "RtlFillMemory"(ByVal 目的内存 As String,ByVal 长度 As Long,ByVal 填充内容 As Any) As Long
  9. Declare Function LoadLibraryA Lib  "kernel32.dll" Alias  "LoadLibraryA"(ByVal 动态链接库名称 As String) As Long
  10. Declare Function GetProcAddress Lib  "kernel32.dll" Alias  "GetProcAddress"(ByVal 模块句柄 As Long,ByVal 进程名称 As String) As Long
  11. Declare Function GetModuleHandleA Lib  "kernel32.dll" Alias  "GetModuleHandleA"(ByVal 模块名 As String) As Long
  12. Declare Function SetWindowsHook Lib  "user32.dll" Alias  "SetWindowsHookExA"(ByVal 钩子类型 As Long,ByVal 回调函数地址 As Long,ByVal 实例句柄 As Long,ByVal 线程ID As Long) As Long
  13. Declare Function UnhookWindowsHookEx Lib  "user32.dll" Alias  "UnhookWindowsHookEx"(ByVal 钩子句柄 As Long) As Long
  14. Declare Function RtlZeroMemory Lib  "kernel32.dll" Alias  "RtlZeroMemory"(ByVal 目的内存 As String,ByVal 长度 As Long) As Long
  15. Declare Function MultiByteToWideChar Lib  "kernel32.dll" Alias  "MultiByteToWideChar"(ByVal CodePage As Long,ByVal dwFlags As Long,ByVal lpMultiByteStr As Long,ByVal cchMultiByte As Long,ByVal lpWideCharStr As Long,ByVal lpWideCharStr As Long) As Long
  16. Function 取指针长度(指针)
  17. If 指针 > 0 Then
  18.         取指针长度 = LocalSize(指针)
  19.         Else
  20.         TracePrint "错误的指针!"
  21. End If
  22.
  23. End Function
  24. Function 指针到文本(指针)
  25.   JS_txt_anjian = space(取指针长度(指针)\2)
  26.   RtlMoveMemory JS_txt_anjian, 指针, 取指针长度(指针)
  27.   指针到文本=JS_txt_anjian
  28. End Function
  29. Function  写代码(汇编代码)
  30.     Dim 局部数组, 指令集,临时值
  31.     指令集="EAX|EBX|ECX|EDX|ESP|EBP|ESI|EDI|AX|BX|CX|DX|AL|BL|CL|DL|AH|BH|CH|DH|DI|SI|BP|SP|IP|EIP|CS|DS|ES|SS"
  32.     //G_code_text = G_code_text + 汇编代码 + chr(10)
  33.     G_测试=汇编代码
  34.     If 汇编代码 <> "" Then
  35.         If Asm(G_测试, Len(G_测试)) = 0 Then //如果编译器认为出错
  36.             局部数组 = split(汇编代码, " ")
  37.             Select Case UBound(局部数组)
  38.             Case 0//为单一指令时,报错
  39.                 TracePrint "错误的指令>>>" + 汇编代码
  40.                 G_code_text = "XXXXXXXX"
  41.                 Goto OVER
  42.             Case 1// 为带操作数指令时,判断是否为调用函数
  43.                 临时值 = 取址(局部数组(1))
  44. //                TracePrint 临时值
  45.                 If 临时值>0 Then
  46.                     G_code_text = G_code_text + 局部数组(0) + " " + Cstr(临时值) + chr(10)
  47.                 Else
  48.                     If InStr("LOOP|JMP|JE|JNE|JB|JNB|JA|JNA|JCC|JZ|JE|JNZ|JNE|JS|JNS|JO|JNO|JP|JPE|JNP|JPO|JC|JB|JNAE|JNC|JNB|JAE", UCase(局部数组(0))) >= 0 Then
  49.                             if UBound(split(局部数组(1),","))=0 then
  50.                         G_code_text = G_code_text + 汇编代码 + chr(10)
  51.                             Goto over
  52.                         end if
  53.                     End If
  54.                     局部数组 = split(汇编代码, ",")
  55.                     If UBound(局部数组) = 1 Then
  56.                         临时值 = 取址(局部数组(1))
  57.                         If 临时值>0 Then
  58.                             G_code_text = G_code_text + 局部数组(0) + "," + Cstr(临时值) + chr(10)
  59.                         Else
  60.                             TracePrint "汇编代码:" + 汇编代码 + " 错误!" + "     位置>>>" + 局部数组(1)
  61.                            G_code_text = "XXXXXXXX"
  62.                             Goto OVER
  63.                         End If
  64.                     Else
  65.                         TracePrint "库中无此函数>>>" + 汇编代码
  66.                         G_code_text = "XXXXXXXX"
  67.                         Goto OVER
  68.                     End If
  69.                 End If
  70.             End Select
  71.             //         TracePrint "汇编代码语法有误!错误的代码>>>【 " + G_测试+" 】"
  72.         Else
  73.             G_code_text = G_code_text +汇编代码+chr(10)
  74.         End If
  75.     End If
  76.     Rem OVER
  77.     写代码= 汇编代码
  78. End Function
  79. Function 运行代码Ex(代码指针,可选参数1, 可选参数2, 可选参数3, 可选参数4)
  80. if 代码指针<>0 then
  81. 运行代码Ex=CallWindowProcA(代码指针, 可选参数1, 可选参数2, 可选参数3, 可选参数4)
  82. Else
  83.    TracePrint "无效的指针"
  84.    运行代码Ex=0
  85. end if
  86. End Function
  87. Function 取代码指针()
  88. Dim 字节, 指针,数量
  89. 数量 = Asm(G_code_text, Len(G_code_text))//编译
  90. If 数量 > 0 Then
  91. CODE_字节 = space(数量)
  92. MultiByteToWideChar 0, 0, G_code_text, - 1 , CODE_字节, 数量//转换
  93. G_code_text=CODE_字节
  94.    字节 = split(G_code_text, "{")
  95.    字节 = split(字节(1), "}")
  96.    字节 = split(字节(0), ",")
  97.    取代码指针 = 写内存代码(字节)//装载
  98.    G_code_text = ""
  99.    Else
  100.    TracePrint "当前代码存在错误!请仔细检查。"
  101.    取代码指针 =0
  102. End If
  103. End Function
  104. sub 释放指针(指针)
  105. call LocalFree (指针)
  106. End sub
  107. Function 运行代码(可选参数1, 可选参数2, 可选参数3, 可选参数4)
  108. Dim 字节, 指针,数量
  109. 数量 = Asm(G_code_text, Len(G_code_text))//编译
  110. If 数量 > 0 Then
  111. CODE_字节 = space(数量)
  112. MultiByteToWideChar 0, 0, G_code_text, - 1 , CODE_字节, 数量//转换
  113. G_code_text=CODE_字节
  114.    字节 = split(G_code_text, "{")
  115.    字节 = split(字节(1), "}")
  116.    字节 = split(字节(0), ",")
  117.    指针 = 写内存代码(字节)//装载
  118. 运行代码 = CallWindowProcA(指针, 可选参数1, 可选参数2, 可选参数3, 可选参数4)//运行
  119.    G_code_text = ""
  120.    LocalFree 指针
  121.    Else
  122.    TracePrint "当前代码存在错误!请仔细检查。"
  123. End If
  124. End Function
  125. Function 取址(函数名)
  126.     Dim DLL集,lz,i,z
  127.     DLL集 = "kernel32.dll|user32.dll|winmm.dll|gdi32.dll|wininet.dll|"
  128.     DLL集=DLL集+dll_Name
  129.     lz=split(DLL集,"|")
  130.     For i = 0 To UBound(lz)
  131. TracePrint lz(i)
  132.         z = 取函数地址(lz(i), 函数名)
  133.         If z > 0 Then
  134.             Exit For
  135.         End If
  136.     Next
  137.     取址 = z
  138. End Function
  139. Sub 载入DLL(Dll名)
  140.     dll_Name=dll_Name+dll名+"|"
  141.     call LoadLibraryA(dll名)
  142. End Sub
  143. Function 取函数地址(dll名, 函数名)
  144.     Dim i,字节组,文本数组,字节数组,模块句柄,文_本_指_针
  145.     文_本_指_针 = LocalAlloc(0, len(函数名) + 1)
  146.     For i = 1 To len(函数名)
  147.         字节组=字节组&Asc(mid(函数名,i,1))&","
  148.     Next
  149.     字节组 = 字节组 & "0"//Null结束符
  150.     文本数组 = split(字节组, ",")
  151.     字节数组 = 文本数组
  152.     For i = 0 To UBound(文本数组)
  153.         字节数组(i)=Cint(文本数组(i))
  154.     Next
  155.     字符_指针 = 写内存代码(字节数组)
  156.     模块句柄 = GetModuleHandleA(dll名)//先尝试获取模块句柄
  157.     If 模块句柄 <= 0 Then
  158.         模块句柄=LoadLibraryA(dll名)//如果模块没有加载,则加载
  159.     End If
  160.     //    MessageBox  模块句柄
  161.     取函数地址=GetProcAddress(模块句柄,字符_指针)
  162.     LocalFree 字符_指针
  163. End Function
  164. Function 取数组指针(整数数组)'返回数组的首地址,构建和C语言一样的线性数组。
  165.     Dim 数组地址,结构指针
  166.     If VarType(整数数组) = 8204 Then
  167.         数组地址 = LocalAlloc(0, (UBound(整数数组) + 1) * 4)//申请内存构建数组,申请临时内存,用于取巧写整数,并内存清零!!
  168.         结构指针 = LocalAlloc(0, 16)
  169.         RtlFillMemory 数组地址, UBound(整数数组) + 1, 0
  170.         RtlFillMemory 结构指针, 16, 0
  171.         Dim 实际传送次数,写入指针,i//计算需要传送的次数,每次传送4个整数。不足4个算做4个。
  172.         实际传送次数 = UBound(整数数组)  + 1
  173.         实际传送次数 = 实际传送次数 \ 4
  174.         If 实际成员数 mod 4 <> 0 Then
  175.             实际传送次数 =实际传送次数+1
  176.         End If
  177.         写入指针=0//定义变量设置传送写入位置,开始循环写入,如果满4个,全部一起传送
  178.         For i = 0 To 实际传送次数
  179.             If i <= 实际传送次数 - 1 Then
  180.                 Call SetRec(结构指针, 整数数组(i*4), 整数数组(i*4+1), 整数数组(i*4+2), 整数数组(i*4+3))
  181.                 Call RtlMoveMemory (数组地址+写入指针*16, 结构指针, 16)//一次传送4个整数到内存。
  182.                 写入指针 = 写入指针 + 1
  183.                 //TracePrint i& "|" &整数数组(i * 4) & "|" & 整数数组(i * 4 + 1) & "|" & 整数数组(i * 4 + 2) & "|" & 整数数组(i * 4 + 3)
  184.             ElseIf i > 实际传送次数 - 1 Then//如果到了最后一次,可能不满4个
  185.                 If i * 4 = UBound(整数数组) Then //如果还剩一个
  186.                     Call SetRec(结构指针, 整数数组(i * 4), 0, 0, 0)
  187.                     Call RtlMoveMemory(数组地址 + 写入指针 * 16, 结构指针, 4)//传送1个整数到内存。
  188.                     //TracePrint "剩余1"
  189.                     Exit For
  190.                 ElseIf i * 4 + 1 = UBound(整数数组) Then//如果还剩二个
  191.                     Call SetRec(结构指针, 整数数组(i * 4), 整数数组(i * 4+1), 0, 0)
  192.                     Call RtlMoveMemory(数组地址 + 写入指针 * 16, 结构指针, 8)//传送2个整数到内存。
  193.                     //TracePrint "剩余2"
  194.                     Exit For
  195.                 ElseIf i * 4 + 2 = UBound(整数数组) Then//如果还剩3个
  196.                     Call SetRec(结构指针, 整数数组(i * 4), 整数数组(i * 4+1), 整数数组(i * 4+2), 0)
  197.                     Call RtlMoveMemory(数组地址 + 写入指针 * 16, 结构指针, 12)//传送3个整数到内存。
  198.                     //TracePrint "剩余3"
  199.                     Exit For
  200.                 ElseIf i * 4 + 3 = UBound(整数数组) Then//如果还剩4个
  201.                     Call SetRec(结构指针, 整数数组(i * 4), 整数数组(i * 4+1), 整数数组(i * 4+2), 整数数组(i * 4+3))
  202.                     Call RtlMoveMemory(数组地址 + 写入指针 * 16, 结构指针, 16)//传送4个整数到内存。
  203.                     //TracePrint "剩余4"
  204.                     Exit For
  205.                 End If
  206.             End If
  207.         Next
  208.         //TracePrint "写数组指针值:"&写入指针
  209.         写入指针=0
  210.         LocalFree 结构指针//释放临时申请的内存。
  211.         取数组指针 = 数组地址 //返回数组所在的地址。
  212.     Else
  213.         取数组指针=0
  214.         TracePrint "这不一个整数型数组"
  215.     End If
  216. End Function
  217. Function 写内存代码(字节数组)
  218.     Dim  i,临时数组
  219.     //写一个函数本身需要的汇编代码到内存,这个写的方试比汇编慢,用于支持第二步的进行。
  220.     临时数组 = Array(83, 51, 192, 51, 219, 139, 93, 12, 138, 69, 16, 136, 3, 91, 195)//汇编代码,写内存字节
  221.     Ccode = LocalAlloc(0, UBound(临时数组) + 1)
  222.     临时地址 = LocalAlloc(0, 16)
  223.     For i = 0 To UBound(临时数组)
  224.         Call SetRec (临时地址, 临时数组(i), 0, 0, 0)
  225.         Call RtlMoveMemory (Ccode+i, 临时地址, 1        )//拷贝到代码地址
  226.     Next
  227.     //申请内存装载汇编代码,及内存清零处理。
  228.     CS_code = LocalAlloc(0, UBound(字节数组) + 1)
  229.     RtlFillMemory CS_code, UBound(字节数组) + 1, 0
  230.     //把主代码写到内存
  231.     //    MessageBox  UBound(字节数组)
  232.     For i = 0 To UBound(字节数组)
  233.         call  CallWindowProcA(Ccode, CS_code + i, Clng(字节数组(i)), 0, 0)
  234.     Next
  235.     //返回和释放资源
  236.     写内存代码 =CS_code
  237.     LocalFree Ccode
  238.     LocalFree 临时地址
  239. End Function
复制代码
